USB sound card
USB sound card
Permanent link to this post Posted by brymct » Mon Mar 12, 2018 7:02 pm
My internal sound card died and I found a good deal on a USB sound card. It works great, but audacity will not record from it. I used the "preferences" menu and selected "USB Audio Device" under both playback and recording, and that is what shows in the dropdown bar in audacity as well. Does anybody have any idea of what I'm missing????? It's got to be some stupid oversight on my part, but I can't figure it out.
Barry
Side note:my USB sound card is identified as device 1 under "devices" in the "help" menu, so Audacity knows it's there.
brymct
Operating System: Windows XP
Re: USB sound card
Permanent link to this post Posted by kozikowski » Mon Mar 12, 2018 7:03 pm
The first thing missing is the name and model of your new soundcard.
Re: USB sound card
Permanent link to this post Posted by DVDdoug » Mon Mar 12, 2018 7:44 pm
I assume you're recording from a microphone? Did the mic work with your old soundcard?
Does your old soundcard have separate mic & headphone jacks, or a combo jack? Is this a laptop or a desktop/tower computer? (I assume the USB soundcard has separate jacks?)
What broke? Maybe it will still record if it can't play? Or maybe your mic broke and your old soundcard is OK?
Or maybe it's defective...
DVDdoug
Forum Crew
Re: USB sound card
Permanent link to this post Posted by kozikowski » Mon Mar 12, 2018 7:58 pm
Right. It's rough to do troubleshooting without knowing more about the hardware.
Re: USB sound card
Permanent link to this post Posted by brymct » Sun Mar 18, 2018 10:58 am
This is not a mic problem- since I don't use one. I've been trying to copy a podcast I heard. The podcast plays fine, but Audacity doesn't "hear" it. I have it set for USB sound card, but it just doesn't work.
brymct
Re: USB sound card
Permanent link to this post Posted by DVDdoug » Sun Mar 18, 2018 6:44 pm
In that case you're not really using the soundcard either but you need to "tap into' the drivers. See Recording Computer Playback.
This can be tricky because normally you record from the ANALOG sound coming INTO the soundcard, but in this case you're trying to capture what's coming OUT (or what's going-in digitally). It depends on your version of Windows and your drivers.
Since you have two soundcards, be sure to select the one the sound is coming out of so you're tapping-into the correct drivers.
That would probably work if you plug a mic to the USB soundcard. ;) But, now we know you' don't want to do that.
DVDdoug
Forum Crew
Return to Windows
Who is online
Users browsing this forum: No registered users and 8 guests
