The effect sc4_1882.dll
Permanent link to this post Posted by юра00 » Tue Mar 06, 2018 9:46 am
I can't find the page, how to use it. Please, help.
юра00
Re: The effect sc4_1882.dll
Permanent link to this post Posted by steve » Tue Mar 06, 2018 10:20 am
Here: http://manual.audacityteam.org/man/sc4.html
The easy way to find effects in the manual is to click on the "Effects" link in the Navigation panel on the left of each page of the manual. That will take you to this page, which lists all of the shipped effects: http://manual.audacityteam.org/man/inde ... yzers.html
Permanent link to this post Posted by юра00 » Tue Mar 06, 2018 12:45 pm
Thank you! You could have found it on the page, where the effects are in alphabetical order. By the way, why this effect doesn't turn off. When you install (in Add/Remove Plug-ins...) "Disabled", the next time you start it changes to "Enabled".
юра00
Permanent link to this post Posted by юра00 » Tue Mar 06, 2018 3:32 pm
In addition, it turned out that it doesn't close after application. You still have to click "Close". Please correct.
юра00
Permanent link to this post Posted by steve » Tue Mar 06, 2018 4:32 pm
Please read the instructions before complaining: http://manual.audacityteam.org/man/real ... fects.html
Permanent link to this post Posted by юра00 » Tue Mar 06, 2018 5:30 pm
Tell me, please, when discussing the effect of "Bass and treble" the idea of ​​the option "Close after application" was suggested. Is it possible to provide and in this case?
viewtopic.php?f=56&t=93355
And from "Bass and treble" refused, including because of the "real-time preview".
юра00
Permanent link to this post Posted by steve » Tue Mar 06, 2018 5:44 pm
Would you like me to log your interest in this feature:
"Real-time preview effects to have a method to apply and close in one go"
Permanent link to this post Posted by юра00 » Wed Mar 07, 2018 7:03 am
Thank you!
юра00
Permanent link to this post Posted by юра00 » Wed Mar 07, 2018 9:56 am
Question about the effect. What are the "Effect Output" lines (Amlitude, Gain reduction) for? At me they remain empty, both before and after working.
юра00
Permanent link to this post Posted by steve » Wed Mar 07, 2018 12:10 pm
юра00 wrote:What are the "Effect Output" lines (Amlitude, Gain reduction) for?
This effect was not written specifically for Audacity. It is a "plug-in" effect, primarily intended for "real-time" processing. When used in a real-time DAW, those two lines will show the input signal level and the output signal level. In Audacity, they may do nothing.
Next
Return to Windows
Who is online
Users browsing this forum: No registered users and 14 guests
