Audacity will not play, record etc.
swataz
Post by swataz » Mon Mar 05, 2018 3:36 pm
Using Windows 10.
This applies to versions 2.1.3 and 2.2.2 but likely is happening with all versions.
I completed two large projects of voiceover last month without this issue occurring, but for whatever reason, whenever I choose a certain speaker output now (the one I used for those entire projects), Audacity will not PLAY, RECORD, etc.
This renders it useless as an editing tool.
Has anyone else experienced this?
Thanks,
-Nick
DVDdoug
Forum Crew
Re: Audacity will not play, record etc.
Post by DVDdoug » Mon Mar 05, 2018 4:42 pm
Does this "certain speaker output" work with Windows Media Player?
Are you running any other audio applications? There is a WASAPI Exclusive Mode that can take-over a sound device and block everything else, so some other application may be blocking you out. And, if you are using WASAPI, try DirectSound.
