Laptop becomes Microphone
Permanent link to this post Posted by WimB » Wed Feb 28, 2018 2:43 pm
New in the field of sound. Audacity 2.2.1. The software is our Toshiba laptop Satelite C870 with Windows 10 Home Version 1703 Intelceleron CPU B830 Soundcard Intel Display audio Realtek High Definition Audio.
The problem. When I work with Audacyti I hear all the surrounding sound on the headphones. The whole is a bad microphone. I was also difficult to turn off the laptop.
I connected a keyboard to the laptop with midi usb 1in / 10ut interface from tie-products.com.
WimB
Re: Laptop becomes Microphone
Permanent link to this post Posted by DVDdoug » Wed Feb 28, 2018 7:53 pm
You can select a recording device from the Device Toolbar.
Audacity is NOT a MIDI application. Does your interface support audio and MIDI?
If you can't get it to work, please give us the model number of your interface and maybe a link to the specs.
DVDdoug
Forum Crew
Permanent link to this post Posted by kozikowski » Wed Feb 28, 2018 8:29 pm
As above, MIDI isn't music. My musical keyboards have MIDI and then headphones, so I adapted the headphone connection to my recorders.
This can be an adventure because most laptops, including Macs don't have stereo Line-In connections any more.
For those conditions, I use a Behringer UCA202 whose job it is to get good quality stereo in and out of a computer.
Permanent link to this post Posted by WimB » Thu Mar 01, 2018 9:30 am
Thanks in advance.
A bit stiff with the Audacitye and the laptop and what appears when I press the red recording button is already recorded sound.
There are no devices connected to it. So the Yamaha keyboard and the midi usb 1in / out interface from [url=http://www.tie-products.com/products/]tie-products.com[/url] have nothing to do with it.
I now realize, in the screen of the laptop is a lens and two holes that could be microphones.
Would Audacyti use it. Can you turn that off somewhere?
MME is shown in the bar. Mic Realtek High and 2 recording channels.
The laptop is dated and has a microphone and a headphone connection.
Would you be grateful if you could find out if this could work.
Google translate helps me to make this message.
WimB
Permanent link to this post Posted by WimB » Thu Mar 01, 2018 1:04 pm
Just a supplement. In device management of Windows Audio-In and Output the microphone turned off. No effect.
Toshiba is also quite present with software that is hidden could it get in the way?
WimB
Permanent link to this post Posted by Trebor » Thu Mar 01, 2018 9:42 pm
WimB wrote:I now realize, in the screen of the laptop is a lens and two holes that could be microphones ...
disable built-in microphone(s) via Windows recording devices ...
Audacity does not understand MIDI from your keyboard.
You need a line-out signal from the keyboard, (not midi),
and a line-in socket on the computer, (or an adapter to convert a USB socket into line-in socket).
Trebor
Permanent link to this post Posted by WimB » Fri Mar 02, 2018 10:55 am
Thanks. It was a search. Roll the arrow up symbol at the bottom right of the screen,
speaker symbol right mouse button, menu recording devices.
Audacity is no longer a microphone and further looking for sound from the Yamaha.
WimB
Return to Windows
Who is online
Users browsing this forum: Google [Bot] and 13 guests
