Total novice here so I apologize for the questions.
Permanent link to this post Posted by paruffus » Tue Feb 27, 2018 9:20 pm
When I open Audacity 2.2.1 I find Audacity at 0.0 but when I select 'record' it jumps back to
-7.0 even though the recording starts at 0.0. I must have changed a setting somewhere.
Also I'm unable to discover how to play back recordings on the speakers in my computer.
Can you help? Thank you.
paruffus
Operating System: Windows 7
Re: Total novice here so I apologize for the questions.
Permanent link to this post Posted by DVDdoug » Wed Feb 28, 2018 3:16 am
Make sure your Playback Device is set to your speakers.
I'm not sure about this one, but check the Latency / Buffer length. The default should be 100mS.
DVDdoug
Forum Crew
Return to Windows
Who is online
Users browsing this forum: No registered users and 5 guests
