Vocoder effect doesn't work.
Permanent link to this post Posted by BlueMage » Mon Feb 26, 2018 5:59 pm
I'm trying to use the vocoder effect but it doesn't work.
I'm on Windows 10, using Audacity v. 2.2.2
I tried following a tutorial: I imported a voice file and made it the left channel, and put a sawtooth tone in the right channel. Then I combined them into a stereo track, then I higlighted it and tried running the Vocoder effect with various parameters.
When I run it the tracks are unchanged. When I check the debug window it says:
Code: Select all
error: (a2 <= -1) or (1 - a2 <= |a1|) (unstable parameters a1 = -1.99997, a2 = -1.00089) in biquad
Function: #<Subr-ERROR: #edd88f0>
Arguments:
  "(a2 <= -1) or (1 - a2 <= |a1|) (unstable parameters a1 = -1.99997, a2 = -1.00089) in biquad\n"
Function: #<FSubr-IF: #edda320>
Arguments:
  (OR (<= A2 -1) (<= (- 1 A2) (ABS A1)))
  (ERROR (FORMAT NIL "(a2 <= -1) or (1 - a2 <= |a1|) (~A a1 = ~A, a2 = ~A) in biquad~%" "unstable parameters" A1 A2))
Function: #<FSubr-LET: #edd5a40>
Arguments:
  ((A0R (/ 1 A0)))
  (SETF A1 (* A0R A1) A2 (* A0R A2))
  (IF (OR (<= A2 -1) (<= (- 1 A2) (ABS A1))) (ERROR (FORMAT NIL "(a2 <= -1) or (1 - a2 <= |a1|) (~A a1 = ~A, a2 = ~A) in biquad~%" "unstable parameters" A1 A2)))
  (SND-BIQUAD X (* A0R B0) (* A0R B1) (* A0R B2) A1 A2 0 0)
Function: #<Closure-NYQ:BIQUAD: #ec34fd0>
Arguments:
  #<Sound: #9c1f4b8>
  -0.000447076
  0
  0.000447076
  0.999553
  -1.99907
  -1.00045
Function: #<Closure-NYQ:BIQUAD-M: #ec34890>
Arguments:
  #<Sound: #9c1f4b8>
  -0.000447076
  0
  0.000447076
  0.999553
  1.99907
  1.00045
Function: #<FSubr-LET*: #edd8330>
Arguments:
  ((W (* 2 PI (/ HZ (SND-SRATE X)))) (CW (COS W)) (SW (SIN W)) (ALPHA (* SW (SINH (/ 0.5 Q)))) (A0 (+ 1 ALPHA)) (A1 (* -2 CW)) (A2 (- 1 ALPHA)) (B0 ALPHA) (B1 0) (B2 (- ALPHA)))
  (NYQ:BIQUAD-M X B0 B1 B2 A0 A1 A2)
Function: #<Closure-NYQ:BANDPASS2: #ec32610>
Arguments:
  #<Sound: #9c1f4b8>
  8077.56
  34.0577
Function: #<Subr-APPLY: #edd7040>
Arguments:
  (#<Sound: #9c1f4b8> 8077.56 34.0577)
Function: #<FSubr-SETF: #edd5860>
Arguments:
  (AREF RESULT I)
  (APPLY FN (MAPCAR (FUNCTION (LAMBDA (A) (COND ((ARRAYP A) (AREF A I)) (T A)))) ARGS))
Function: #<FSubr-DOTIMES: #edd9280>
Arguments:
  (I LEN)
  (SETF (AREF RESULT I) (APPLY FN (MAPCAR (FUNCTION (LAMBDA (A) (COND ((ARRAYP A) (AREF A I)) (T A)))) ARGS)))
Function: #<FSubr-COND: #edd8990>
Arguments:
  (LEN (SETF RESULT (MAKE-ARRAY LEN)) (DOTIMES (I LEN) (SETF (AREF RESULT I) (APPLY FN (MAPCAR (FUNCTION (LAMBDA (A) (COND ((ARRAYP A) (AREF A I)) (T A)))) ARGS)))) RESULT)
  (T (APPLY FN ARGS))
Arguments:
  (LEN NEWLEN RESULT)
  (DOLIST (A ARGS) (COND ((ARRAYP A) (SETF NEWLEN (LENGTH A)) (COND ((AND LEN (/= LEN NEWLEN)) (ERROR (FORMAT NIL "In ~A, two arguments are vectors of differing length." FN)))) (SETF LEN NEWLEN))))
  (COND (LEN (SETF RESULT (MAKE-ARRAY LEN)) (DOTIMES (I LEN) (SETF (AREF RESULT I) (APPLY FN (MAPCAR (FUNCTION (LAMBDA (A) (COND ((ARRAYP A) (AREF A I)) (T A)))) ARGS)))) RESULT) (T (APPLY FN ARGS)))
Function: #<Closure-MULTICHAN-EXPAND: #ebc3d00>
Arguments:
  #(#<Sound: #9c1f4b8> #<Sound: #9c197c0>)
  8077.56
  34.0577
Function: #<Closure-BANDPASS2: #ec32d70>
Arguments:
  8077.56
  34.0577
Arguments:
  BAND
  (BANDPASS2 S F Q)
Function: #<FSubr-DO*: #edd6f90>
Arguments:
  ((I 0 (1+ I)) MOD-ENVELOPE BAND (RESULT 0) (Q (/ (SQRT 2) (/ OCTAVES BANDS))) (P (+ (HZ-TO-STEP 20) (/ INTERVAL 2)) (+ P INTERVAL)) (F (STEP-TO-HZ P) (STEP-TO-HZ P)))
  ((= I BANDS) RESULT)
  (SETF BAND (BANDPASS2 S F Q))
  (SETF MOD-ENVELOPE (LOWPASS8 (S-ABS (AREF BAND 0)) (/ F DST)))
  (SETF RESULT (SUM RESULT (BANDPASS2 (MULT MOD-ENVELOPE (AREF BAND 1)) F Q)))
Function: #<Closure-VOCODER: #ed69c68>
Arguments:
  S
  (VOCODER)
Arguments:
  ((ORIGINAL (OR (= MST 0) (AREF S 0))))
  (SETF S (VOCODER))
  (SETF S (SCALE (/ (PEAK S NY:ALL)) S))
  (CASE MST (0 S) (1 (VECTOR ORIGINAL S)))
Arguments:
  ((ARRAYP S) (MIX) (LET ((ORIGINAL (OR (= MST 0) (AREF S 0)))) (SETF S (VOCODER)) (SETF S (SCALE (/ (PEAK S NY:ALL)) S)) (CASE MST (0 S) (1 (VECTOR ORIGINAL S)))))
  (T "Error.\nStereo track required.")
1>
Thanks.
Reason: replace quote tags with code tags
BlueMage
Re: Vocoder effect doesn't work.
Permanent link to this post Posted by steve » Mon Feb 26, 2018 6:10 pm
I need to know what settings you are using.
The default settings as shown here, work fine for me:
Permanent link to this post Posted by steve » Mon Feb 26, 2018 6:14 pm
Are you applying the effect to a low sample-rate track?
The track sample rate is shown in the panel on the left end of the track.
If the sample rate is less than 44100, use the "Tracks menu > Resample" command to resample the track to 44100 before you apply the vocoder effect.
Permanent link to this post Posted by BlueMage » Tue Feb 27, 2018 1:50 am
I tried resampling to 44100Hz and now it works fine. Thank you. :D
BlueMage
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 43 guests
