join 2 sections of mp3
Permanent link to this post Posted by simonwales » Sun Feb 25, 2018 1:04 pm
Hello,i'm running windows 7 64 bit and audacity 2.2.2.I have an mp3 track which i need to shorten by cutting out the middle piece and then joining the 2 remaing pieces together,can this be done.thanks
simonwales
Operating System: Windows 7
Re: join 2 sections of mp3
Permanent link to this post Posted by steve » Sun Feb 25, 2018 1:35 pm
Yes, just select and delete the middle bit, then export the result.
You may find the "Getting Started" tutorials helpful: http://manual.audacityteam.org/quick_help.html
Return to Windows
Who is online
Users browsing this forum: No registered users and 22 guests
