Break an audiobook down into chunks
Permanent link to this post Posted by metis2be » Sun Feb 25, 2018 1:47 am
I want to back up an audiobook, but I don't want a 15 hour long mp3. What is an easy way to break down the file into 30 minute chunks that I can add to a playlist? Windows 7 Audacity 2.2.1
metis2be
Operating System: Windows 7
Re: Break an audiobook down into chunks
Permanent link to this post Posted by kozikowski » Sun Feb 25, 2018 2:04 am
That you presented, or you bought?
If you presented it, you can go back to the individual chapter boundaries you made when you submitted.
I know there's a way to label at predictable points, but I can't find it....
Permanent link to this post Posted by kozikowski » Sun Feb 25, 2018 2:08 am
There it is.
Analyze > Regular Interval Labels.
You an use the labels later to Export individual sound files at those breaks.
If there is enough silences in the chapter breaks, you can try Analyze > Silence Finder or Analyze > Sound Finder.
Permanent link to this post Posted by kozikowski » Mon Feb 26, 2018 3:43 am
Missed a step. After you form the labels (don't forget to put one at the beginning), File > Export > Export Multiple.
Return to Windows
Who is online
Users browsing this forum: Menges and 26 guests
