Metadata tag window
Metadata tag window
Permanent link to this post Posted by alpha45 » Thu Feb 22, 2018 12:43 pm
Hello,
using the previous versions of 2.2.2, when exporting a file to MP3, the window shown in the attachment did not appear as it appears in this version.
Is it possible to prevent it from being displayed?
Thank you
Windows 7
https://drive.google.com/file/d/15-IqcDKLfobaEIZ-lvYoUJP2fDxkdtrh/view?usp=sharing
alpha45
Operating System: Windows 7
Re: Metadata tag window
Permanent link to this post Posted by steve » Thu Feb 22, 2018 12:54 pm
Turn off the option "Show Metadata Tags editor before export" in "Edit menu > Preferences > Import / Export".
See: http://manual.audacityteam.org/man/impo ... ences.html
Permanent link to this post Posted by alpha45 » Thu Feb 22, 2018 12:58 pm
steve wrote:Turn off the option "Show Metadata Tags editor before export" in "Edit menu > Preferences > Import / Export".
sorry I did not notice.
thank you :oops:
alpha45
Permanent link to this post Posted by steve » Thu Feb 22, 2018 1:05 pm
No problem. Happy to help.
Funnily enough, the Metadata editor has always been enabled by default, so you must have found the setting sometime in the past (easy to forget if it was a long time ago ;))
Return to Windows
Who is online
Users browsing this forum: Menges and 29 guests
