Recording pauses unless record input is set too high
Permanent link to this post Posted by George Averill » Wed Feb 21, 2018 8:42 pm
I'm using Windows 7 and Audacity 2.2.2. Trying to copy an LP to a CD.
I finally got the internal laptop mike to stop recording by simply turning it off in the computer.
Now Audacity pauses and does not record unless the record input is set so high that it splatters.
How can I get Audacity to record at a lower record level?
George Averill
Operating System: Windows 7
Re: Recording pauses unless record input is set too high
Permanent link to this post Posted by kozikowski » Wed Feb 21, 2018 9:28 pm
That sounds like Sound Activated Recording.
Audacity > Edit > Preferences > Recording > [_] Sound Activated Recording (de-select).
Permanent link to this post Posted by kozikowski » Thu Feb 22, 2018 1:59 am
There was one completely wacky problem that cropped up here and there. If Sound Activate Recording is already de-selected, Select it > OK. Restart Audacity, go back in and de-select it.
Return to Windows
Who is online
Users browsing this forum: Bing [Bot], Google [Bot], lonepilgrim and 20 guests
