Audio recording: quality loss after a while
Permanent link to this post Posted by maxime.dubois » Tue Feb 20, 2018 3:37 pm
Hello,
I am using Audacity 2.1.2 on an Asus laptop with Windows 10.
I try to record guitars (either accoustic or electric) directly with the laptop microphone.
It works fine at the beginning, but after a while the sound becomes suddenly bad, as if it was in very low quality.
I tried to change the recording settings (record volume, mono / stereo, MME / Windows DirectSound / Windows WASAPI), but I always get the same result.
I attached a sample sound of guitar recording in which you can clearly hear the quality loss at 13:00.
Does anybody know where this problem could come from?
Thanks.
Maxime
test.mp3
Sample sound
(710.2 KiB) Downloaded 7 times
maxime.dubois
Re: Audio recording: quality loss after a while
Permanent link to this post Posted by DVDdoug » Tue Feb 20, 2018 5:24 pm
I didn't listen to your recording, but turn off Windows "Enhancements".
DVDdoug
Forum Crew
Permanent link to this post Posted by kozikowski » Wed Feb 21, 2018 1:55 am
What he said. Unless you change it, Windows sees extended musical notes as "Room Noise" and is determined to protect your important corporate conference call from that damage.
That's what Windows is thinking. Windows hasn't been a generic recorder in a long time.
Permanent link to this post Posted by maxime.dubois » Thu Feb 22, 2018 1:27 pm
It works!!! Thank you for this quick answer!
Actually, when I searched the internet for a solution to my problem, I found this page about Windows "Enhancements". I tried to change some parameters to prevent the tunnel effect, but I kept the Noise Suppression checked. I didn't know my music could be considered as noise by Windows. It's something you generaly expect from your neighours, not from your operating system...
Anyway, now I can record my music thanks to you guys, so thanks a lot!
Maxime
maxime.dubois
Permanent link to this post Posted by kozikowski » Thu Feb 22, 2018 5:54 pm
I do. Windows isn't magic. The only way it can tell the difference between your voice and noise is the noise is usually sustained...like a musical note. If you hold one note long enough for Windows to detect it, it's gone. Windows will attack it with a stick (if you leave that setting on).
So it's actually worse than you say. Your music is a cousin to air conditioner vent and computer fan noise.
Return to Windows
Who is online
Users browsing this forum: No registered users and 48 guests
