Decibel/ volume reader
Re: Decibel/ volume reader
Permanent link to this post Posted by Toolless » Tue Feb 20, 2018 1:19 am
So it is looking more and more like Audacity will not work as a volume recorder for me
kozikowski wrote:https://www.galaxyaudio.com/products/cm-130
Or, oddly...
https://itunes.apple.com/us/app/spl-met ... 06756?mt=8
The first link is a device for sale that dose not give a price or an online price to buy and the second link is only for apple software and will not run on my windows (IBM based) computer
Thanks
Toolless
Toolless
Permanent link to this post Posted by kozikowski » Tue Feb 20, 2018 1:46 am
Permanent link to this post Posted by Toolless » Tue Feb 20, 2018 8:48 pm
kozikowski wrote:https://www.sweetwater.com/store/detail/CM130
Wow $60! thats a lot of money
Toolless
Permanent link to this post Posted by steve » Tue Feb 20, 2018 9:02 pm
If you look around (example: Amazon) you can find SPL meters from under $20, but don't expect a cheap one to be very accurate, or be able to measure low level sound.
For a "Class 1" calibrated SPL meter, you could be paying well over $3000.
Permanent link to this post Posted by kozikowski » Wed Feb 21, 2018 1:43 am
That's the one you use if someone is suing your company for hearing damage. That's also the one you use when you're setting up a new screening room for clients writing big checks.
Permanent link to this post Posted by Toolless » Wed Feb 21, 2018 5:25 am
Well to be honest it was nothing spectacular then all that. I needed it to read about 100-130 db (or in 20 microns as you called it under your program)
A lot of those apps that will not run on win O/S (IBM base) only go upto 80-96 db, so not a lot of good there
Toolless
Previous
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 13 guests
