How to lag a record
How to lag a record
Permanent link to this post Posted by Ylantron » Tue Feb 13, 2018 2:22 pm
Hello everybody! I've tried to search this everywhere but the research always shown me problems on computer freezing or crashing or how to fix record delays. I actually want to add them in a record, like if pc is freezing. If you need an example for what i'm trying to do I put a wav in the attachments as an example. Can I do this with Audacity? If not is there a program out there that can do it?
lag_attachment.wav
(958.45 KiB) Downloaded 8 times
Ylantron
Re: How to lag a record
Permanent link to this post Posted by Trebor » Tue Feb 13, 2018 5:22 pm
Ylantron wrote:...Can I do this with Audacity? If not is there a program out there that can do it?
The magic words are glitch & stutter . There are glitch plugins or you can manually repeat a short section of audio
Trebor
Permanent link to this post Posted by Ylantron » Tue Feb 13, 2018 6:50 pm
it seems that the repeat effect is doing is job although i would have preferred some easier methods. thank you
Ylantron
Return to Windows
Who is online
Users browsing this forum: Trebor and 11 guests
