Help Please> trouble playing 192k flac files
Re: Help Please> trouble playing 192k flac files
Permanent link to this post Posted by steve » Tue Feb 13, 2018 2:22 am
Posts crossing.
Dougr33 wrote:Would I change it back to 192k before exporting the flac to maintain the higher bit rate?
Why not cut out one sample rate conversion and leave it at 96 kHz?
(96 kHz sample rate is good for frequencies well in excess of 40 kHz, which is double the upper frequency range of human hearing).
Permanent link to this post Posted by Dougr33 » Tue Feb 13, 2018 2:25 am
steve wrote:Posts crossing.
Well, I am recording these 192k steams successfully, and 'want to believe' it's worth it. I have a pretty good dac/amp.
Anyway.. I imagine after I trim, I can change the lower left box back to 192k if all I did was delete some of the file?
edit... that works fine. thanks.
Dougr33
Previous
Return to Windows
Who is online
Users browsing this forum: No registered users and 8 guests
