recording
recording
Permanent link to this post Posted by thankorov » Sat Feb 10, 2018 10:45 am
Windows 8.1
Version 2.2...
First problem
I open or insert a backing audio track in order to record the lead guitar
I record to the first new track and its OK it records only the lead
Trying to record to a new track it records also the previous one. is there any solution to avoid this?
Second
Can I hear the effect (e.g. echo or delay) while I am recording?
thankorov
Re: recording
Permanent link to this post Posted by kozikowski » Sat Feb 10, 2018 1:55 pm
Audacity > Edit > Preferences > Recording.
Make sure [_]Playthrough is not selected, and [X]Overdub is.
Make sure you are recording an actual device like your microphone USB driver. If you like to record on-line content such as YouTube audio, you may be set to record from Stereo-Mix or other "fake" device. The wrong setting can double-up overdubbing sound by accident.
Audacity does not apply effects, filters or corrections in real time. So, no.
Re: recording
Permanent link to this post Posted by Lubasha » Mon Feb 12, 2018 2:46 pm
I checked options as following:
Made sure [_]Playthrough is not selected, and [X]Overdub is.
...but problem persists, the system does not allow me to record multiple tracks as I used to do in old computer before I changed it to new one. It just continues the record on the same track even after I re-installed the program (Audacity 2.2.1)
Please help, what should I do to make multiple trucks (layers) recorded in the same song?
Lubasha
Re: recording
Permanent link to this post Posted by Lubasha » Mon Feb 12, 2018 7:04 pm
As I mentioned in previous post (probably different attributor) I found solution when applied Always record on new track, it brought the magic in. Thanks for help :-)
Lubasha
Return to Windows
Who is online
Users browsing this forum: Bing [Bot], Exabot [Bot] and 15 guests
