latency problem
gsc1ugs
Operating System: Windows 7
latency problem
Post by gsc1ugs » Thu Feb 08, 2018 1:41 pm
Hello,
I'm recording vocals but i have a latency problem, the vocals dont seem to record along with the music, they are either in front micros seconds or behind, i'm using a US-122 BY TASCAM.. I ve looked at preferences but when i change buffer it goes well in front, if a choose zero it make aweful noise
Re: latency problem
Post by steve » Thu Feb 08, 2018 3:56 pm
The buffer setting should normally be about "100".
The setting to adjust is the "Track shift after record" (previously called "Latency correction"). See here for details: http://manual.audacityteam.org/man/devi ... ences.html
gsc1ugs
Re: latency problem
Post by gsc1ugs » Fri Feb 09, 2018 2:34 pm
Great it worked cheers
