Exporting M4A Lossless from v2.2.1 in Win-7
edwinn
Operating System: Windows 7
Re: Exporting M4A Lossless from v2.2.1 in Win-7
Post by edwinn » Mon Feb 05, 2018 7:53 pm
Here's an example of the Excellent HELP file.
Find section on ALAC command line string... under FFmpeg examples:
http://manual.audacityteam.org/man/expo ... ogram.html
Easy to find and implement.
Kudos and thanks for that.
EDIT: found it on page above:
"an exported M4A file with the standard AAC (lossy) codec" i.e. `AAC LC´.
-Ed
edwinn
Post by edwinn » Wed Feb 07, 2018 2:54 pm
Would like to post the final `cleaned up´ file lists, as there were errors and inconsistencies in the file names during experiments.
MediaInfo
The file names are self explanatory.
Hope the programmers could improve the M4A Export dialog box and make in more straight forward.
Thanks,
-Ed
