Audacity 2.2.1 does not load FLAC 24/48000 properly
HappySparks
Post by HappySparks » Sun Feb 04, 2018 3:06 pm
Hi
New to Audacity forums. Using Audacity 2.2.1. I want to edit 24/48000 FLAC files. It does not open the files properly.
It does however open 24/44000 files fine.
In the Preferences/Quality, I changed the default sample rate to 48000.
I did not find an answers in the FAQ or Forum.
What do I need to change, Thank you.
DVDdoug
Forum Crew
Re: Audacity 2.2.1 does not load FLAC 24/48000 properly
Post by DVDdoug » Sun Feb 04, 2018 6:27 pm
I'd guess there's something wrong (or something "different") with your FLAC file.
What's the problem? What kind of error are you getting?
Where did the file come from?
Try checking it with MediaInfo. Make sure it says FLAC with the properties you expect.
I had no problem...
I opened an MP3 (44.1kHz), changed the project rate to 48,000 and exported as 24-bit FLAC. No problems re-opening in Audacity.
I converted the same MP3 to 48kHz/24 FLAC with another program. Again no problem opening in Audacity.
Post by steve » Sun Feb 04, 2018 7:16 pm
HappySparks wrote:I want to edit 24/48000 FLAC files. It does not open the files properly.
It appears to work fine for me.
What is the problem that you are seeing?
