A few songs have been cutting early on my phone, and when I checked the MP3s against the original .FLACs, some were tens of seconds shorter, while most were unaffected. I'll import and export my music using the "import" function and loading in several at a time (The entire album) and exporting to the proper folder in a batch (Export Multiple)
Has this happened to anyone else? Is there any way to fix or prevent this?
2.2.1 Audacity is Clipping Length of Exported MP3 Files?
Re: 2.2.1 Audacity is Clipping Length of Exported MP3 Files?
and the exact three-section version of Audacity from "Help menu > About Audacity".
How are you doing that?Evoconian wrote:when I checked the MP3s against the original .FLACs,
