hi
can anyone recommend a decent cd burner software for me?ive had ashampoo and it stopped audacity form working..i uninstalled ashampoo and audacity is working ok again..any suggestions?
lenny
a good cd burner
Re: a good cd burner
When I was on Windows, I used to use CDBurnerXP.
Some other (free) suggestions here in the manual: http://manual.audacityteam.org/man/burn ... _a_cd.html
I use ImgBurn (for CDs & DVDs).
thanks guys..
lenny
lenny
