Example of type of rhythm track I'm trying to create:
57.7 bpm for 6 minutes, then 59 bpm for 6 minutes starting at 6:01 into the track, then 60 bpm for 11:58 starting at 12:02 int the track.
So far I'm only saving the initial 6 minutes. The rest disappears or was never recorded.
Trying to create a special rhythm track
Re: Trying to create a special rhythm track
1) Generate the first 6 mins,
2) then press the "End" key to move the cursor to the end of the track (or: "Select menu > Region > Cursor to Track End")
3)then generate the next 6 mins
