Problem on Widows7
Problem on Widows7
Permanent link to this post Posted by DjoeGio » Sat Jan 27, 2018 10:42 am
Can not record with Audacity (2.1.2) on Windows7. SoundSoftware used is is Creative SB Audigy 2. I'm using this pc only for playing guitar with Gearbox Line 6. I can hear the guitar fine via the speakers. I have used all settings on Audacity but it does not pick up the sound. What can I do? This is the audio read-out info from Audacity:
Code: Select all
Default recording device number: 1
Default playback device number: 3
Device ID: 0
Device name: Microsoft Sound Mapper - Input
Host name: MME
Recording channels: 2
Playback channels: 0
Low Recording Latency: 0,090000
Low Playback Latency: 0,090000
High Recording Latency: 0,180000
High Playback Latency: 0,180000
Supported Rates:
Device ID: 1
Device name: CD Digital (Creative SB Audigy
Host name: MME
Supported Rates:
Device ID: 2
Device name: Microsoft Sound Mapper - Output
Host name: MME
Recording channels: 0
Playback channels: 2
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
    352800
    384000
Device ID: 3
Device name: SPDIF Out (Creative SB Audigy 2
Host name: MME
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
    352800
    384000
Device ID: 4
Device name: Primary Sound Capture Driver
Host name: Windows DirectSound
Low Recording Latency: 0,120000
Low Playback Latency: 0,000000
High Recording Latency: 0,240000
High Playback Latency: 0,000000
Supported Rates:
Device ID: 5
Device name: CD Digital (Creative SB Audigy 2 (WDM))
Supported Rates:
Device ID: 6
Device name: Primary Sound Driver
Low Recording Latency: 0,000000
Low Playback Latency: 0,120000
High Recording Latency: 0,000000
High Playback Latency: 0,240000
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 7
Device name: SPDIF Out (Creative SB Audigy 2 (WDM))
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 8
Host name: Windows WASAPI
Low Playback Latency: 0,003000
High Playback Latency: 0,010000
Supported Rates:
    48000
Device ID: 9
Device name: SPDIF Out (Creative SB Audigy 2 (WDM)) (loopback)
Low Recording Latency: 0,003000
High Recording Latency: 0,010000
Supported Rates:
Device ID: 10
Supported Rates:
Selected recording device: 10 - CD Digital (Creative SB Audigy 2 (WDM))
Selected playback device: 8 - SPDIF Out (Creative SB Audigy 2 (WDM))
Supported Rates:
    48000
Available mixers:
Available recording sources:
0 - Master
Available playback volumes:
0 - PCM
Recording volume is native
Playback volume is native
Reason: added code tag for readability
DjoeGio
Operating System: Windows XP
Return to Windows
Who is online
Users browsing this forum: Bing [Bot], Exabot [Bot], Google [Bot] and 8 guests
