Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
megabuff
Post
by megabuff » Thu Jan 25, 2018 4:49 am
hi guys
trying to get this better, i did noise removal and played with EQ and its a lot better but hoping for a bit more if possible
any gurus here maybe have some suggestions pls?
win 7
aud 2.1.2
- Use This For 30 days and Watch Your Prosperity Grow.wav
- (1.03 MiB) Downloaded 21 times
Post
by kozikowski » Thu Jan 25, 2018 5:00 am
Did you keep the original? The sample has too much noise reduction. That's what gives it a hollow tube sound. That's permanent. We can't take effects out.
