change pitch in vocal
hazebighaze
Post by hazebighaze » Fri Jan 19, 2018 2:48 pm
I downloaded audacity but most of the effects I want to use can be selected because they are not available to use. Can you help me select pitch bend in the software?
Re: change pitch in vocal
Post by steve » Fri Jan 19, 2018 3:03 pm
and the exact three-section version of Audacity from "Help menu > About Audacity".
Please give exact steps to reproduce the problem.
Note that effects are greyed out if there are no audio tracks in the project.
