2 Versions of Audacity
Pepsiboy
Operating System: Windows 7
Post by Pepsiboy » Thu Jan 11, 2018 11:12 pm
I just updated my audacity. Now I have 2 versions on my computer. I have 2.1.3 and 2.2.1. Can the earlier version be deleted without problems?
I'm running Win 7 SP 1 x64 on a HP G62 laptop with an Intel Pentium P6100 2.0 ghz, also using IE11 for my browser.
Thanks, in advance, for any and all help received.
Dave
Re: 2 Versions of Audacity
Post by kozikowski » Fri Jan 12, 2018 1:05 am
You can totally have more than one Audacity installed on your machine..
Screen Shot 2018-01-11 at 17.03.56.png (9.54 KiB) Viewed 195 times
...But I don't know the proper spells for Windows 7. We should wait for a Windows elf.
Post by kozikowski » Fri Jan 12, 2018 1:06 am
Note you can only use one at a time.
Post by kozikowski » Fri Jan 12, 2018 1:28 am
There are reasons to keep multiple versions around. If you got used to an earlier version and its tools, you can dig yourself out of a hole in a more modern Audacity by Exporting a perfect quality WAV of the work and opening it in the older one you know.
Then you can post on the forum asking what was supposed to happen, while you're holding a finished show.
There are postings from people who did an Audacity update and now can't find the tools to do their work.
Pepsiboy
Post by Pepsiboy » Sun Jan 14, 2018 7:48 pm
Well, I finally got it sorted out. I tried to delete version 2.1.3 and then version 2.2.1 would not work. I tried to reinstall 2.2.1 and 2.1.3 showed up again. SSSOOO, I deleted BOTH of them, did a restart, and installed 2.2.1 again. Now everything works perfectly. I guess when doing an updated version, we need to delete all older versions first, then install the new one.
Works for me ! ! !
Dave
