MP3 Recordings are Bassy as heck.
whatshisname
Post by whatshisname » Thu Jan 11, 2018 2:29 pm
Heyy, I just got a new laptop about a week ago. And i normally record songs off spotify and put them onto audacity then export them.
However, since i've tried to record some songs they've ALL turned out very bassy. Its really annoying, it would be appreciated if you could help out and post any suggestions? :D
DVDdoug
Forum Crew
Re: MP3 Recordings are Bassy as heck.
Post by DVDdoug » Thu Jan 11, 2018 4:39 pm
If you are using "Stereo Mix", try switching to "WASAPI Loopback". If that doesn't help, look for a setting in Windows or your soundcard utility (if your computer has one) that's tying to "enhance" the sound.
Audacity itself only records what's fed-into it... Something else has to be messing-up the sound before it gets to Audacity.
Of course that's a copyright violation and a violation of your Spotify user agreement. The artist only gets paid (a very-very small amount) when the song is played through Spotify.
whatshisname
Post by whatshisname » Fri Jan 12, 2018 12:30 am
I'm not using the stereo mix, Audacity just records it from whatever is playing out of the speakers. And there are no enhancements, I mean when Audacity records its bass, but when I play it out normally its normal.
Contact:
Post by steve » Fri Jan 12, 2018 9:42 am
whatshisname wrote:when I play it out normally
What does that mean?
If you import a known good audio file into Audacity and play it, does it sound "normal" or "bassy as heck"?
If you export an MP3 from Audacity and "play it out normally", does it sound "normal" or "bassy as heck"?
DVDdoug
Forum Crew
Post by DVDdoug » Fri Jan 12, 2018 3:06 pm
Audacity records from whatever Recording Device that you select.
There are few different ways of Recording Computer Playback.
