Good Afternoon,
I have been unable to import these flac files? And have installed the FFmpeg:
https://archive.org/details/Husary_Mual ... c/001.flac
When I attempted to import 'raw data' it is just noise.
What do you advise, please?
Thank you.
Cannot import this flac file/s?
Re: Cannot import this flac file/s?
It worked for me. Are you sure you have the FLAC file? 001.flac is 6.06 MB.
I'm not sure, but I don't think you need FFmpeg for FLAC. Did you try downloading MP3? I know Audacity can open an MP3 file without any add-ons, although you need LAME to make (export) an MP3.
Of course! The raw FLAC data is compressed and it has to be decompressed to get audio. (Compression is sort-of like encryption... It looks like... sounds like... garbage unless it's properly decoded.)When I attempted to import 'raw data' it is just noise.
Aha! I downloaded the wrong file. And it is working now. Thank you. How can I determine if it is an original flac file or if it was another file format and saved as flac?
And I also need to remove echo from the recording, please? I am unsure if it was part of the original or added as an effect. Nevertheless, I need to remove it.
Thank you.
Thank you.
