2.2.1 Install corrupted toolbar and preferences
waxcylinder
Re: 2.2.1 Install corrupted toolbar and preferences
Post by waxcylinder » Mon Jan 08, 2018 6:55 pm
edwinn wrote:One last question... how do I add the Sync-Lock button to the Edit toolbar in 221, like in 213 (see image above)?
You can't any more - we withdrew that button as too many folk were turning it on by accident and getting confused.
Instead use the menu item: Tracks > Sync-Lock Tracks (on/off)
There is no pre-set shortcut for this, but you can set one of your own - see: https://manual.audacityteam.org/man/key ... ences.html
