Will I'll be darn, that Fixed it. THANKSfwm wrote:Probably not appropiate to state my solution to the 'cropping': but this happened when reverting to 2.1.3 (from the lamed 2.2.1).
Resolved by: View > Toolbars > Reset Toolbars - the Icons then being repaired....easy..
What do you mean lamed 2.2.1? some issues?
If I'm going to install the next version (2.2.1 or whatever), will have to uninstall EVERYTHING because the current install folder is `Audacity 2.1.3´
Not sure why I did a stupid thing like appending the version number to the install folder.
I have the Audacity.CFG in a handy TEXT file for reference... because I have a LOT of custom hotkeys set, and other settings.
-Ed
