How to obtain audio clips online???
neenahrose
Operating System: Windows 7
Post by neenahrose » Mon Dec 25, 2017 2:24 pm
Hello and Happy Holidays to all:
I am brand new first day here! I am Neenah I just started taking the Deadmau5 MasterClass to learn EDM that I have always found fascinating. I just downloaded and installed Audacity 2.2.1 on my Windows 7. I want to get started but honestly lost. They say importing audio files to use to build my music. However, can anyone suggest where there are free or reasonable priced audio clips compatible with Audacity that I can download? I would appreciate if you can post the link to me?? I don't have any equipment to make the audio clip myself I am literally starting out with just the PC and the software and that is literally it. Thank you all and take care! Neenah :D
Re: How to obtain audio clips online???
Post by kozikowski » Mon Dec 25, 2017 7:56 pm
Audacity is most often used for production on work made by the user. AudioBook reading, musical performances, etc. I suspect the course is probably assuming you already have works you bought (or performed) if you're interested in this kind of production.
I get most of my music from iTunes download at whatever price is quoted.
Screen Shot 2017-12-25 at 11.54.51.png (52.38 KiB) Viewed 397 times
neenahrose
Post by neenahrose » Mon Dec 25, 2017 11:02 pm
Thank you sooo much!
Neenah
Trebor
Post by Trebor » Tue Dec 26, 2017 6:14 am
neenahrose wrote:...can anyone suggest where there are free or reasonable priced audio clips compatible with Audacity that I can download?
https://freesound.org/search/?q=EDM
neenahrose
Post by neenahrose » Tue Dec 26, 2017 3:38 pm
You ROCK! Thank you sooooo much!
Post by kozikowski » Tue Dec 26, 2017 10:43 pm
Audacity can open up a lot of different found files, but if you find one that doesn't work, you may need to install the FFMpeg plug-in. That expands Audacity's dance card to a large number of different files.
Scroll Down.
http://www.audacityteam.org/download/windows/
neenahrose
Post by neenahrose » Tue Dec 26, 2017 11:44 pm
Good to know thank you I am totally green at this
