Cannot Import Playlist - not recognising the type of file
MHarran
Post by MHarran » Fri Dec 22, 2017 9:28 am
I have a .m3u playlist that I have converted to LOF using the instructions here.
When I try to import the file I get "Audacity did not recognise the type of file ....".
Here is the file (a short list for testing) in case there is a syntax error though I don't think that is the problem.
Code: Select all
file "F:\OneDrive\My Music\GooglePlay\01 - A Silent Night Christmas 1914.mp3"
file "F:\OneDrive\My Music\Spotify\20171217\Brenda Shine - Christmas Time Ireland_Various Artists.mp3"
file "F:\OneDrive\My Music\Spotify\20171217\In The Bleak Mid-Winter_Tommy Fleming.mp3"
file "F:\OneDrive\My Music\Spotify\20171217\Oíche Chiún (Silent Night)_Enya.mp3"
file "F:\OneDrive\My Music\Spotify\20171217\Santa & The Kids_Gene Stuart.mp3"
file "F:\OneDrive\My Music\Spotify\20171217\Santa Looks a Lot Like Daddy_Ray Lynham.mp3"
file "F:\OneDrive\My Music\Spotify\20171217\Snowflake_Lrry Cunningham.mp3"
file "F:\OneDrive\My Music\YouTube\Liam Harkin - Silent Night (Saxophone).mp3"
Re: Cannot Import Playlist - not recognising the type of fil
Post by steve » Fri Dec 22, 2017 11:15 am
MHarran wrote:When I try to import the file
For LOF files, use "File menu > Open".
The name of the LOF file must end with ".lof"
MHarran
Post by MHarran » Fri Dec 22, 2017 11:22 am
steve wrote:For LOF files, use "File menu > Open".
I tried that, Steve, but getting the same "Audacity did not recognise the type of file ...." error as when I try Import; also tried dragging the LOF file from Explorer into the Audacity pane but taht doesn't work either.
I'm wondering if maybe I need some sort of plugin to do this - I am using Version 2.1.2 with all default settings.
Post by steve » Fri Dec 22, 2017 11:35 am
MHarran wrote:"Audacity did not recognise the type of file ...."
What is the full and complete error message?
What program did you use to make the LOF file?
MHarran
Post by MHarran » Fri Dec 22, 2017 11:53 am
' Error Importing
Audacity did not recognize the type of the file 'F:\OneDrive\My Music\Playlists\ TestAudacity.LOF'
If it is uncompressed, try importing it using "Import Raw". '
steve wrote:What program did you use to make the LOF file?
The playlist was originally created as an export from MediaMonkey; I opened and modified it in Noptepad++ .
Post by steve » Fri Dec 22, 2017 1:23 pm
Which version of Audacity are you using? (Help > About Audacity)
Check (in NotePad++) what the file encoding is of the LOF file.
MHarran
Post by MHarran » Fri Dec 22, 2017 3:20 pm
steve wrote:Which version of Audacity are you using? (Help > About Audacity)
Version 2.1.2
steve wrote:Check (in NotePad++) what the file encoding is of the LOF file.
It was originally in UTF-8-BOM. I've tried with ANSI and UTF 8 encoding but get the same error.
Post by steve » Fri Dec 22, 2017 6:12 pm
What is drive F?
MHarran
Post by MHarran » Fri Dec 22, 2017 6:25 pm
steve wrote:What is drive F?
It's the drive where I store my music.
Post by steve » Fri Dec 22, 2017 6:56 pm
Internal? External? USB? Flash drive? Network drive? ...
