How to copy effects from one file to another?
RPG Crunch
Post by RPG Crunch » Thu Dec 21, 2017 6:09 pm
Hi,
I'm a new user of Audacity. I'm making a series of sound clips for use in a tabletop roleplaying game as "sound effects".
I already made a track with the "perfect" effects applied to the track and I want to copy those same effects and settings to other tracks as well.
Is this possible? And if so, how do I do it?
Tnx for the help.
RPG Crunch
Re: How to copy effects from one file to another?
Post by RPG Crunch » Thu Dec 21, 2017 6:40 pm
And I'm using 2.2.1.
Post by steve » Thu Dec 21, 2017 7:46 pm
If you can remember what effects you used, you could make a "Chain", and then apply that Chain to other tracks / files.
See: http://manual.audacityteam.org/man/chai ... ation.html
