Display problem
Black Hole
Display problem
Post by Black Hole » Wed Dec 20, 2017 8:21 pm
Why do numbers appear in reverse?
thank you all
Re: Display problem
Post by steve » Thu Dec 21, 2017 12:11 am
Black Hole wrote:Why do numbers appear in reverse?
because right to left language implementation is flawed, as can be seen from the numbers on the timeline. Getting it to work correctly is very difficult, especially as there are RTL bugs in WxWidgets (which is the GUI toolkit that Audacity uses).
Black Hole
Re: Display problem
Post by Black Hole » Thu Dec 21, 2017 5:56 am
Thank you for your clarification
