Hi:
I am brand new to Audacity. The first instruction that I can find to record says -
"SET THE RECORDING DEVICE"
Please tell me what that means - what I am to do.
Thank you
NEW USER AND CONFUSED
Re: NEW USER AND CONFUSED
Do you have the current version of Audacity installed (2.2.1)? If not, get it from here: https://www.audacityteam.org/download/
What are you wanting to record, and with what equipment?
Goals are good. What would you like to do? It's good not to crank up detailed servicing until we find out what the poster wants as a product.
I want to record about 3 minutes of audio for use as a short podcast.
Equipment is a Logitech usb headset.
