Annoying Graphic Implied Clipping Noundaries
Lairbear
Operating System: Windows 7
Post by Lairbear » Fri Dec 15, 2017 7:57 pm
How (through settings) do I eliminate (pronounced: expunge) what I consider to be the annoying graphical highlighting of what seems to be the clipping boundaries in the audio graph for an OPENed audio file. I find this feature to be most annoying, and unwanted!!! To quote the Queen: "My Husband ans I are NOT amused"!
Re: Annoying Graphic Implied Clipping Noundaries
Post by steve » Fri Dec 15, 2017 8:40 pm
If you are referring to the red vertical "clip indicator" lines (as shown below), then deselect "Show Clipping" in the View menu.
(more info: http://manual.audacityteam.org/man/view ... w_Clipping)
