I am using Windows 10 and version 2.0.3.0 of Audacity.
I have read and re-read posts from three years ago about aligning numerous recorded tracks (each track is one song) "end-to-end" so that the final file can combine many songs on one CD. So far, this is the process I understand to use is:
Edit
Select
All tracks
Tracks
Align tracks
At this point there are about a dozen choices and I've tried them all and don't get the results I want.
FYI, I'm trying to digitize hundreds of 45s on as few CDs as possible. Thank you.
"Align tracks" question
DigitalDave
Re: "Align tracks" question
That's a very old version. I don't think it has "Align end to end".DigitalDave wrote:I am using Windows 10 and version 2.0.3.0 of Audacity.
The current version is 2.2.1 and is available via the Audacity website: https://www.audacityteam.org/download/windows/
With the current version:
1) Ctrl + A (select All)
2) Tracks menu > Align Tracks > Align End to End
(http://manual.audacityteam.org/man/trac ... racks.html)
