no sound or record win 10
wanker
Post by wanker » Sat Dec 09, 2017 6:37 pm
I have downloaded 2.1.1 for windows 10 but cannot record or get sound no sound wave
Re: no sound or record win 10
Post by steve » Sun Dec 10, 2017 10:53 am
Topic moved to the Windows forum.
wanker wrote:I have downloaded 2.1.1 for windows 10
That's an old version. Uninstall it, then get the current version (2.2.1) from here: https://www.audacityteam.org/download/windows/
If you are using a USB audio device, ensure that it is connected and working before you start Audacity. You can check if the device is working from the Windows Sound Control Panel.
After launching Audacity, select the device that you want to record from in the device toolbar.
