I downloaded the upgraded Audacity program version 2.2.1. However, I can not choose the "recording device" or "recording channels." It was there in the last version. What can I do?
b2sing4u
Recording Device with 2.2.1
Re: Recording Device with 2.2.1
What is your recording device? Is it properly connected and working?
