Hi,
I had a previous version of Audacity which wouldn't allow me to do anything as it became non-responsive upon opening a project or importing a file. I've upgraded to 2.2.1 and I can't open my previous project.
Help please!
Audacity 2.2.1 non-responsive
Re: Audacity 2.2.1 non-responsive
Perhaps your previous projects are damaged in some way.HWDacity wrote:I've upgraded to 2.2.1 and I can't open my previous project.
If you create a new project in 2.2.1, does that work?
When you try to open a previous project, what exactly happens?
