A Good working bitcrusher for the newest audacity version?
TinyMan360
- Operating System: Windows 8 or 8.1
I have been looking for a bitcrusher that works in audacity and is easy to use but the ones i have found either no longer work or cannot save with the effect still applied, does anyone know where i could find one that works?
Re: A Good working bitcrusher for the newest audacity versio
VST plugins will play (mostly) in Audacity.
https://bedroomproducersblog.com/2012/0 ... u-plugins/
dblue Crusher (simple) & dblue glitch* (complex) are are old & free & in this pack ...TinyMan360 wrote:I have been looking for a bitcrusher that works in audacity ...
http://illformed.org/downloads/illforme ... lugins.zip
[* dblue glitch includes a bit-crush effect ]
