EXtracting audio from mkv
Permanent link to this post Posted by bigguy4909 » Mon Nov 13, 2017 7:44 pm
New to forum.
Have an mkv file from which I would like to extract the audio track, preferably to flac. Where might I find a detailed procedure?
Thanks in advance.
bigguy4909
Re: EXtracting audio from mkv
Permanent link to this post Posted by steve » Mon Nov 13, 2017 8:56 pm
You will need to install FFmpeg: http://manual.audacityteam.org/man/inst ... html#winff
Matroska (MKV) is a container format, so it is not guaranteed that FFmpeg will be able to decode the contents, but for a 'normal' MKV file, once you have FFmpeg installed, it's just a matter of:
1) Launch Audacity
2) Import the MKV file (For Audacity 2.2.0: "File menu > Import > Audio")
3) Export as FLAC (For Audacity 2.2.0: "File menu > Save Other > Export Audio")
Permanent link to this post Posted by Trebor » Mon Nov 13, 2017 11:28 pm
steve wrote:2) Import the MKV file (For Audacity 2.2.0: "File menu > Import > Audio")
Or drag'n'drop the MKV file into Audacity window ...
Trebor
Return to Windows
Who is online
Users browsing this forum: Monte, waxcylinder and 16 guests
