Audacity Export option inexistent
Permanent link to this post Posted by wbezerra » Sun Nov 12, 2017 11:26 pm
Windows 10 Audacity 2.2.0
I have been trying for a couple of hours now to make this damn file export but the issuee I have is that audacity will not let me import the file as a wav, simply because it only allows me to save it as an aup file and te export option simply is not there.
Issue when importing.
wbezerra
Re: Audacity Export option inexistent
Permanent link to this post Posted by steve » Sun Nov 12, 2017 11:42 pm
In Audacity 2.2.0, the export options are in "File menu > Save Other" (http://manual.audacityteam.org/man/file ... other.html)
This was done as an attempt to help people that could not find how to 'save' an audio file. Unfortunately it seems to have confused as many as it helped, so the next Audacity release will bring back an "Export" menu item.
Permanent link to this post Posted by Trebor » Mon Nov 13, 2017 12:06 am
wbezerra wrote:... audacity will not let me import the file as a wav, simply because it only allows me to save it as an aup file and te export option simply is not there.
If you double-click on the aup-file it should open in Audacity, then save a copy in WAV format ...
saving as WAV in Audacity 2-2-0.gif (83.49 KiB) Viewed 366 times
Trebor
Return to Windows
Who is online
Users browsing this forum: No registered users and 17 guests
