Hidden files put on puter?
SDL
Operating System: Windows 7
Post by SDL » Sat Nov 11, 2017 5:41 am
Hi...Just recently started using version 2.1.3 on a HP 'puter that uses Windows 7.
I've noticed that after i record a project and then delete it after it has been burned to a CD there appears to be something on my hard drive that takes up some space.
Example. When I started a project, I started with 567:30 of disk space. When I was done recording, the readings said 565:30. After I exported the project to my desktop , burned the project to CD and deleted the project .wav file, the reading was 566:50. I then cleared the cache and ran scans. Final reading was 567:23.
What is accounting for those 13 minutes? Is there a hidden file created when I exported the project to my desktop? Can it be easily cleared off my hard drive?
Thanks!
Trebor
Re: Hidden files put on puter?
Post by Trebor » Sat Nov 11, 2017 4:58 pm
Audacity does not keep copies of the file you create. The CD-burning program could possibly retain a copy of the ISO image. But anything could have used-up that memory space, e.g. a Windows update.
If you want to securely-delete data, a good free program is CCleaner ... https://en.wikipedia.org/wiki/CCleaner
SDL
Post by SDL » Sat Nov 11, 2017 5:51 pm
I use CCleaner and I still had had that discrepancy.
Trebor
Post by Trebor » Sat Nov 11, 2017 11:18 pm
SDL wrote:...Is there a hidden file created...
There is a hidden Audacity folder called "SessionData" ...
Code: Select all
C:\Users\<YourNameHere>\AppData\Local\Audacity\SessionData
But that folder is cleared when Audacity is closed.
