file name
Shauncowdy
Operating System: Windows 7
file name
Post by Shauncowdy » Wed Nov 08, 2017 7:13 pm
I have windows 7. I have exported to wav but it will not let me type in file name. Can anybody help ? Shaun
Re: file name
Post by kozikowski » Wed Nov 08, 2017 8:29 pm
Which three-number version of Audacity do you have?
Is Audacity stopped and not just paused?
Are you using plain filenames: upper and lower case letters, numbers, dash and underscore?
I can't think of a normal mistake which will prevent typing characters into a filename box..... Is your flashing cursor in the box?
Shauncowdy
Re: file name
Post by Shauncowdy » Thu Nov 09, 2017 8:34 am
Hi Koz
I have USB turntable D6027 and Audacity 1 2 6 on my computer. I have recorded the album I want, then go into File then Export to wav. The cursor then flashes in file name. I can't use upper and lower case, numbers, dash and underscore. Hope you can help. Shaun
Re: file name
Post by steve » Thu Nov 09, 2017 11:07 am
Audacity 1.2.6 is ancient and no longer supported.
Audacity 2.2.0 is available via the Audacity website: https://www.audacityteam.org/download/windows/
