Audio Leveling
Audio Leveling
Permanent link to this post Posted by Chuckcobb3 » Tue Nov 07, 2017 2:16 pm
The audio leveling effect has been removed from the latest version of Audacity and I’m unsure of an alternative approach for doing that. I do a lot of audio narration that I embed in PowerPoint files and sometimes the levels will be different between two or more audio recordings that I have combined. What is the best way to do audio leveling with the latest version of Audacity?
Thanks,
Chuckcobb3
Re: Audio Leveling
Permanent link to this post Posted by steve » Tue Nov 07, 2017 2:40 pm
The "Limiter" provides a similar effect to the old Leveler effect, but with much less distortion. http://manual.audacityteam.org/man/limiter.html
If you want the distortion that the Leveler effect gave, there are settings in the "Distortion" effect that are virtually identical to the old Leveler effect. http://manual.audacityteam.org/man/distortion.html
Re: Audio Leveling
Permanent link to this post Posted by kozikowski » Tue Nov 07, 2017 2:42 pm
If you mean "leveler," it's still there under Effect > Distortion > Leveler.
Re: Audio Leveling
Permanent link to this post Posted by kozikowski » Wed Nov 08, 2017 1:29 am
Leveler used to be a generic audio processing tool except it did it by brute force distorting waveforms, much like some broadcast limiters do. Much better, more graceful audio production tools were developed and Leveler was going to be put out in the back alley for trash pickup when some of us put up our hands and objected.
The distortion could be useful.
It's included in Distortion Effects because multiple passes through highest possible limiting is a dead ringer for Airline Pilot, Taxi Driver, Two-Way Radio and Ground Control voices.
"ROGER LUFTHANSA NINETY NINE HEAVY, CLEAR FOR LANDING TWO FOUR RIGHT."
It's just terrifically hard to get that voice using the other tools.
Re: Audio Leveling
Permanent link to this post Posted by Chuckcobb3 » Mon Nov 13, 2017 9:59 pm
OK, thanks...I didn't understand the purpose of the "Limiter" so I have been using it incorrectly for a while. Here's the problem I'm trying to solve - I add a lot of audio narration to PowerPoint slide shows and the level of each slide or the level of an audio segment within a particular slide might be somewhat different. I would like to fix that so that the levels are more consistent. What is the best way to do that?
Thanks,
Chuckcobb3
Re: Audio Leveling
Permanent link to this post Posted by Trebor » Tue Nov 14, 2017 2:13 am
Chuckcobb3 wrote:... the level of each slide or the level of an audio segment within a particular slide might be somewhat different. I would like to fix that so that the levels are more consistent. What is the best way to do that?
One of two Audacity plugins : "LevelSpeech" or "AGC", see ... viewtopic.php?p=336945#p336945
Here's how to install those plugins into Audacity ... http://wiki.audacityteam.org/wiki/Download_Nyquist_Plug-ins#install
Trebor
Re: Audio Leveling
Permanent link to this post Posted by steve » Tue Nov 14, 2017 9:57 am
The latest version of the "Level Speech" plug-in is now available on the Audacity wiki: http://wiki.audacityteam.org/wiki/Nyqui ... vel_Speech
A new version of "AGC" will be going on the wiki very soon - perhaps later today.
Return to Windows
Who is online
Users browsing this forum: No registered users and 41 guests
