1) how to select track portion as delineated by the selected label points
(shown up as the Start / end Points in the Selection Bar?) for editing/exporting etc?
The Label Track portion is highlighted, but the Sound Wave (Mono) track portion is not;
"Export Selected" not available;
the Start/End in the Selected toolbar filled.
No reference seen from : Label Tracks - Audacity Development Manual -
http://manual.audacityteam.org/man/labe ... navigating
How to select the segment between Label Points
Re: How to select the segment between Label Points
The desperation method is zoom out (Control-3) until both label points are visible. Drag-select the sound. Labels are sticky/magnetic.
An alternative to click and drag:LCheni wrote:1) how to select track portion as delineated by the selected label points
1) Select the audio track and the label track (if there is just one audio track and one label track you can use Ctrl+A to select All)
2) Edit menu > Labeled Audio > Split (splits the audio track at each label position to create a series of separate audio clips)
You can now quickly and easily select an audio clip by double clicking on it.
If you want to re-join a single split, click on it.
