Activation context generation failed for "c:\program files (x86)\Audacity\audacity.exe".Error in manifest or policy file "" on line . A component version required by the application conflicts with another component version already active. Conflicting components are:. Component 1: C:\Windows\WinSxS\manifests\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18837_none_fa3b1e3d17594757.manifest. Component 2: C:\Windows\WinSxS\manifests\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18837_none_41e855142bd5705d.manifest.
any clue why im repeatedly getting this error in my system log on windows 7 pro version?
thank you
conflicting component versions events on system log
Re: conflicting component versions events on system log
I am running Windows 7 ULTIMATE SP1 x64...
I just noticed I am getting these ERRORS..
Audacity still loads are runs tough..
whats even stranger is I found a bunch of these errors real early this morning..
and I HAVE NOT run Audacity is days for weeks.. since I last used it.. pretty sure..
Provider Name = SideBySide
EventID = 80
EventID = 80
I don't know a great deal about these errors, but from what I understand, they are non-critical and may safely be ignored.
