no replay gain
bookworm2575W
Operating System: Windows 7
no replay gain
Post by bookworm2575W » Fri Oct 13, 2017 11:16 am
replay gain is not an option in my audacity. What do I do?
How do I control volume?
Re: no replay gain
Post by steve » Fri Oct 13, 2017 11:25 am
What are you trying to do?
DVDdoug
Forum Crew
Re: no replay gain
Post by DVDdoug » Fri Oct 13, 2017 3:24 pm
There is a an optional ReplayGain.ny plug-in (which I think Steve wrote) but Audacity doesn't actually support ReplayGain... You wouldn't want an audio editor automatically messing with the playback volume behind your back. And, the plug-in doesn't write ReplayGain tags to your file.
So it's not really ReplayGain... You can think of it as a ReplayGain tool. Or, you can think of it as a Loudness Tool that uses the same loudness analysis algorithm as ReplayGain.
