Tab to a mark like a text file
DeLaVega1944
Post by DeLaVega1944 » Thu Oct 12, 2017 11:44 pm
In Audacity when i make a mistake I can make a sound to mark the spot where it is for editing out, etc.
However, is another way to mark that segment of the file and "tab tab tab" to each mistake like you can on a text file,WITHOUT having to listen to the entire file?
Trebor
Re: Tab to a mark like a text file
Post by Trebor » Fri Oct 13, 2017 12:04 am
DeLaVega1944 wrote:... is another way to mark that segment of the file and "tab tab tab" to each mistake like you can on a text file,WITHOUT having to listen to the entire file?
Make labels, rather than add sounds, to mark point on the track ...
You can jump to last/next label using "Alt"+"←", "Alt"+"→", (rather than "tab").
