Removing all metadata when exporting multiple
ahonoe
Operating System: Windows 7
Post by ahonoe » Thu Oct 12, 2017 11:09 pm
Hi!
Wondering how to remove all metadata when exporting multiple wavs. (My app requires no metadata be present.) Audacity seems to be automatically adding the filename in the Title field, and a series of hex values in the Comments field.
Thanks,
Scott
Contact:
Re: Removing all metadata when exporting multiple
Post by steve » Fri Oct 13, 2017 2:52 pm
Before you start exporting, open "File menu > Edit Metadata" and remove all of the metadata.
You can then disable the Metadata Editor from popping up during export, by deselecting the setting in "Edit > Preferences > Import / Export -> Show Metadata Tags editor prior to export step"
ahonoe
Post by ahonoe » Fri Oct 13, 2017 3:03 pm
Thanks for your reply, Steve, Unfortunately this approach still puts/leaves values in the Title and Comments fields.
I'm using version 2.0.3. Perhaps that's my problem?
Scott
Contact:
Post by steve » Fri Oct 13, 2017 3:42 pm
I don't have 2.0.3 (it's very old) so I can't test.
The current version is 2.1.3 which you can get from here: https://www.audacityteam.org/download/
